Shutdown problems on A8N32SLI Deluxe
FSH42NA
My new computer build is driving me nutso. Intermittently my computer will just go into a rebooting loop when I shutdown. Here are my specs:
ASUS A8N32 SLI Deluxe; Bios 903 (same prob with 1009)
X2 3800 (mild oc to 2200mhz)
2 x 1gb OCZ PC3200 Platinum
MSI 6600GT x 2 in SLI
Samsung 200gb SATA x 3 (non-raid)
Benq 1640 pri. master; LG 4163 sec. master
Onboard sound
Enermax 600w Noisetaker ps
XP pro w/ sp2 slipstreamed
Lian Li PC65
My memory has been tested with Memtest on both this board and the ASUS A8N sli platinum with no errors (probably a total of 30 loops at various oc settings). The drives have been tested with the Samsung diagnostic utility. I've run Prime 95 overnight. Short of a bad mobo, the only thing I can think of is the power supply or my memory settings. Recommended settings for memory with this mobo have been difficult to find, but I did find some info over at bleedinedge.com :http://www.bleedinedge.com/forum/showthread.php?t=16547&highlight=guldur
Anyways, please chime in with any thoughts or advice on what it sounds like the source of my problem is.
Thanks in advance for your replies
Kenai,
thanks for the response. I've already visited that forum (I'm "fsh42na" there also). However, the people there seem to have issues installing their OS on the Nvidia sata controller. I didn't have any problems installing the OS. On the other hand, maybe my install isn't as glitch free as I'm thinking. Maybe there is a corrupted file or two that is causing my problem. I don't "think" I'm having any ACPI issues since I didn't get any such error messages during my install. OCZ tech has given me some rec'd memory timings so I'll probably make those settings and reinstall the OS/ reflash the bios (though not in this order) and see what happens.
