When I shutdown my SN25P/WinXP Pro system, it doesn't turn off from time to time. Does anybody know how can I figure out what's causing this and how can I fix it?
I am having the same problem with my Hypersonic Aviator ZX7 I push the button down to turn of the laptop and the system looks like it's going thru the "normal" shut down process then I get the message that it's now safe to turn of my system?
Maybe it's a hardware problem or software system maybe even a bios setting I'll have to check that one out and I'll post later about what I find.
Good luck with your system.
Thx
HogLeg
