this is a bug with the Nforce drivers, disable restart on system failure, you will find this option when you right click on My computer-Properties-Advanced-Startup and Recovery.
Once you do that, you will get a driver error of file nv_agp.sys creating problems. The only solution I have found is deleting this file. You however need this file if you go back to AGP.
