Question "Showroom build" gone bad? (HP ProDesk 400 G3 total conversion) boot loops? SOLVED.
VirtualLarry
56,570
10,202
So I transplanted an HP ProDesk 400 G3 mini-Tower with a Skylake i5-6500 into a nice case with tempered glass and RGB / rainbow fans. Gave it to my buddy, as a sort-of "showroom piece" for him to show other potential customers and refer them to me. (Edit: IN the past, a few years back.)
He gave the PC to one of his offspring, to use to play RoBlox, FortNite, etc.
I believe that currently, it has a Rosewill PSU that I only just replaced 3-4 month ago, and a GTX 1650 GPU.
It's a moderately-decent gaming rig for e-sports-ish gaming.
My Buddy says that it was boot-looping, and wasn't booting over at his place. When his offspring touched it. it would power-off.
Hr brought it to me, and of course, it fired up no problem, couldn't get it to crash in 30 minutes of running.
I suggested that the power cord might be old and failing, and sent him back with a new one.
That apparently did NOT fix the issue. I suggested that he might have an outlet issue, given other electrical-related failures in both his room and the offspring's.
He swears up and down that he doesn't have outlet issues.
He says that the problem rears itself after 2-3 days of running. Computer freezes, attempts to force power-off and reboot, result in boot-looping. (*)
Which makes me think temps, he thinks PSU (again). I told him that I would replace the PSU under warranty, but that might not actually be the problem.
Thing is, I have a hard time believing it's a temperature problem, unless the cooler is dislodged, but the OEM cooler for these HP mobos is screwed down in four corners. The case has a mesh front and THREE intake fans. And they only have a GTX 1650.
I gave my buddy a 3200G desktop as a backup PC, might ask him to deploy that in the offspring's room, using the same power cord, surge, and outlet, and see if it has the same issues.
(*) I wonder how much of the boot-looping, is the activation of Windows Automatic Recovery? (I know that it reboots several times in the process.) And thus the boot-looping might be a red herring, and instead, system freezing after three days of power-on might be the real problem.
DAPUNISHER
31,211
29,830
I'd plug it into a surge strip at minimum, given the janky electrical at their place. Replacing the PSU is always a good idea. If it keeps boot looping maybe try re-flashing the bios even if it has the latest.
I would have run Malwarebytes on it as soon as I started troubleshooting. Normies cannot be trusted. :p Another SOP is checking the event logs or installing who crashed.
But if the board is flaky I would not be surprised. It might not be dealing with the 1650's power draw properly either. Even with the 6 pin you can see some odd behavior if the PCIE slot only provides 35W or something.
VirtualLarry
56,570
10,202
That's an interesting point that I hadn't fully considered. (But aren't x16 slots supposed to support 75W of power, per spec? Everything else is more-or-less standard micro-ATX spec, PSU and mobo aren't totally proprietary.)
DAPUNISHER
31,211
29,830
You would think that 75W should be standard, but it never was. I have run across OEMs that supply half that from the PCIE slot. You should see if you can find the specs for that board at HP. I would not be surprised if the slot power is rated at 35W.
DAPUNISHER
31,211
29,830
It booted right up at my place while my buddy was there. I did not stress-test the GPU then.
The fact it takes a couple of days to flake out, makes it a tough one. The boot looping points to the board or storage mostly, if the PSU is good.
VirtualLarry
56,570
10,202
PCI express x16 (v 3.0)​
1 - 4.2 in full height, 6.6 in length 75W max. power​
VirtualLarry
56,570
10,202
Memory leak from leaving MMO running for three days straight, didn't check how much of the primary SSD is free, but it's probably a 256GB SATA. Causing Windows to run out of VM, and lock up? (*)
Alterntively, the 3.5" SATA HDD is dying, and causing SATA port / system freezes.
(*) Would this show in Event log as "disk space low" on the OS drive? Before a crash, I mean.
VirtualLarry
56,570
10,202
Swapped PSU, had a spare identical Rosewill 'Lepton' modular PSU. Worked.
Found out that buddy had the PC on (presumably shaggy) carpet. Doh! Intake for PSU is on bottom. PSU died / went wonky, due to being "suffocated", most likely. Had a mm of dust on everything too. Gave buddy a can-o-air, told him to take it outside and blow the dust off, so he did.
Told him to put the PC on a board, or something.
