Show me how to get awesome sound out of my PC
angry hampster
4,232
www.lexaphoto.com
Currently I'm using onboard sound with my M2N-SLI and a cheap ($20) set of logitech 2.1 speakers. They're not bad for most things, but I can definitely notice the difference in this setup and what I've got in my car, or the 5.1 yamaha system in the living room.
Frankly, I don't need 5.1 sound at this computer. There's not enough space in this room to take full advantage of it. I'd like to keep it simple at 2.1, but want clarity throughout the tonal range as well as punchy, powerful and accurate bass.
My motherboard has SPDIF outs as well as a bunch of analog ports, but should I get a sound card? Are speakers the only thing that I need?
As far as usage goes, I'm a huge FPS player. I play TF2, CS:S, and Crysis online quite a bit. When I'm not gaming or watching movies, I'm listening to music through Winamp. If I need to make adjustments with an equalizer, I'll use Winamp's, as it is actually fairly powerful .
Also, space is limited, so a huge receiver and giant bookshelf speakers are likely out of the question.
Thanks in advance.
Ika
14,264
I think you knocked out your best option. Think you can post a pic of your desk so we can see how much room you actually have?
blanketyblank
1,149
Do you have a budget in mind?
There are some 2.1 speakers that can get pretty pricy.
Also have you considered headphones/ear buds?
angry hampster
4,232
www.lexaphoto.com
Yes. I've got a nice pair of Sennheiser headphones, but frankly I'd just rather have good sounding speakers unless I'm trying to keep noise to a minimum.
Aflac: I'll try to post a pic this afternoon.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
