Originally posted by: Sukhoi
I see you failed high school physics.
forget that... the OP failed 5th grade spelling...
Originally posted by: Crescent13
OP Just got owned big time.
Originally posted by: Ktulu
Originally posted by: Garet Jax
Originally posted by: Accipiter22
To achieve a certain speed, say on flat terrain, a 6 cylander would have to work less than a 4 cylander, correct? So why not get better gas mileage?
Assuming all other things equals (weight, wind drag, etc...), it has to ignite more gas to operate the extra 2 cylinders so no.
Yes, but it most likely won't have to rev as high to achieve the same amount of work thus actually using less gas PER CYLANDER.
fixed.
Originally posted by: Colt45
wtf is a cylander
fixed.
Wrong. Those are the best balanced, but they are not the most "efficient".Originally posted by: infestedgh0st
actually, the most efficient internal combustion engine design is the i6 and v12. Friction counts very little in terms of efficiency (motor oil anybody?). Newer engines now usually have lighter internals, which is a big contribution to engine efficiency.
Originally posted by: Zenmervolt
6 cylinder has higher internal friction and while it does make more power, it takes more fuel to make that power.
At 60 mph, most cars only need about 20 hp. Drag increases with the square of speed, so to double speed you need 8X the power (2X power to double speed times 4X the power to overcome the drag associated with the higher speed), so a car that needs 20 hp to go 60 mph would need 160 hp to go 120 mph, which is roughly on track with where a 160 hp car would be hitting top speed (actually, it's over-estimating the required HP slightly as 160 hp should carry a car to about 130-135 mph).
So, at cruise speed, if the 4-cylinder is making 25 hp at 3,000 RPM while the 6 cylinder is making 35 hp at 2,000 RPM, the 4-cylinder is still using less fuel.
Even if both engines were sending 25 hp to the transmission at the same RPMs as above, the 6-cylinder is still using more fuel because of higher internal friction. (E.G. the 4-cylinder may only need to make 27 hp total to send 25 hp to the transmission while the 6-cylinder, due to greater friction, needs to make 30 hp total to send 25 hp to the transmission.)
ZV
Originally posted by: Thraxen
Originally posted by: iwantanewcomputer
i don't know anything about the relationships of torque produced, cylinder number, and fuel consumption of an internal combustion engine, but i am going to post something I just made up based on my limited scientific knowledge that sounds technical.
What's funny is that despite all the snide comments people are actually having a hard time accurately explaining why.... and the people with the snide comments didn't even try to explain.
Originally posted by: GagHalfrunt
And an aircraft carrier should be able to outrun a cigarette boat because the propellers are bigger.
Originally posted by: desy
more moving parts means more friction mechanical loses etc.
The gas engine isn't 100% effecient to start so muliplying cylinders magnifies the loses.
Added vehicle wieght unless you remove something elsewher to keep the GVW the same and on and on
there seems to be a break point around 10 or 12 cylinders, after which addition of cylinders becomes an overall detriment to performance and efficiency, although exceptions such as the W16 engine from Volkswagen exist.
http://en.wikipedia.org/wiki/Internal_combustion_engine#Cylinders
