Should windshield washer fluid be diluted?
rayray2
871
Buddy of mine says you should dilute it with 50% water. I've never heard this before...antifreeze maybe, but not the blue stuff. Is he right? What's the word on the street?
TallBill
46,017
62
you can to save money.. but mines free anyways.. jiffy lube fills it up when i pay them to change my oil.
besides its like 3 bucks for a bottle that lasts months.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Well if you dilute the blinker fluid it makes your blinkers go faster - ask any ricer. Somewhere along the lines of:
Diluting the blinker fluid reduces the damping factor within the can so the bimetal strip has faster decay times and less bounce. The snap action is quicker causing a more rapid rate of breaking and re-engaging the circuit.
Diluting your washer fluid makes the windscreen slicker causing the load on the windscreen wipers to drop. The motors pull less amps during the monsoon season and you will save up to 25 milliliters of petrol over the life of the car!
Ok the OP prolly lives on Earth so...
Diluting makes a bottle go further however adding water makes it much more susceptible to freezing. The lines from the pump to the nozzles are quite thin and it does not take much water to freeze them. Nothing is more irritating than getting a splash on the windscreen and the washer fails to squirt, right?
Britboy
818
No. The stuff sold in the US is meant to be used as-is. They sell it in the UK in concentrate form, a far darker blue color, you have to add 50% water to that, a real pain in the ass on the garage forecourt.
JulesMaximus
74,556
951
100% is fine. You wouldn't want to dilute it if you live where the temps drop below freezing.
The stuff costs $.99 for a gallon. You'd have to be the cheapest motherfvcker on the planet to dilute washer fluid...
D
Deleted member 4644
May as well keep it at 100%. I think it might streak less that way too.
TallBill
46,017
62
well, not entirely true... while deployed getting ahold of enough washer fluid was impossible.. plus water does the trick just fine.
JulesMaximus
74,556
951
Sure in an area where it never gets below zero water is fine. Windshield washer fluid does clean windows better than water though.
YoshiSato
Banned
Jul 31, 2005
1,012
The blue,green and pink stuff should be used 100%
For thoes that do not know
The Bule is every day stuff.
The pink stuff genearlly has rainX and some deicer mixed in
The green stuff is total crap. They say it's 5x stronger than the blue and has a "fresh pine sent" This stuff is just horrible. You can smell it through your AC vents and it's not a pleasent sent.
thedarkwolf
9,030
123
It only gets below freezing a few months a year. Rest of the time its water for me.
Thegonagle
9,773
That's OK if you're trying to cheap out and it never gets below freezing where you live.
But it is intended to be used at full strength.
i thoguht those blue things say not to use it below 32F cuase it will freeze.. and i have seen it do so ..when i accidently hit it and it froze on to my windhield.. i had to deice it with the heater at high going at the window.
I use teh pink stuff in winter.. it works better.. no freezing as such. The green stuff is bugoff.. it takes bugs off real easy..
Thegonagle
9,773
Never squirt the blue stuff without the front defroster running in very cold weather.
The reason "blue stuff" freezes so quickly is because the "anti-freeze" in the solution is just plain isopropyl alcohol. Once it hits the windshield, it evaporates from the solution very quickly, leaving mostly water behind to freeze on the windshield.
conehead433
5,569
901
Bought some of the green stuff with wax in it a while back and wasn't satisfied with the results. The wax seemed to actually reduce visibility. I'm sticking with the regular blue stuff now.
DivideBYZero
24,117
You can buy premix in the UK, too.
And we have phones now, and TV. And Street lamps.
loic2003
3,844
RTFM
It's written on the back of the bottle, do what it says. If there's no mention of diluting it, put it in neat. If there's mention of diluting it to a set concentration, decide which you need and act accordingly. Did you really need to post this on an internet forum? I'd be embarrased to ask.
