- May 17, 2011
- 32
- 0
- 66
Hey guys, I've been googling around this problem for a while now but I'm still not too sure and most information I've found has been pretty dated, so I figured I'd just make a new thread.
To get started, relevant info I guess, I have the 45nm e8400 and an abit ip-35e mobo with the latest BIOS (had to update to install e8400). All temps are consistent across realtemp, coretemp, speedfan, etc.
I picked up a used E8400 a little while ago on the forums, about a month back. I'm not sure how new it was, I don't think he was actually using it, was selling a few of them, etc...
So anyways, I installed it, put a CM Geminii S heatsink/fan on it, booted up...and was surprised. My old processor was an E6600, and I only had the stock cooler, and my temperatures were around the low 30s idle. I read the E8400s were supposed to be really cool, but my idle temps were showing 38C, hotter than I was hoping to see.
But the temperature doesn't fluctuate at all. The heatsink's fan was too noisy for me, so I changed it out for something quieter, no change. I didn't have any AS5 handy when I got the sink, so I just used the stuff it came with and later replaced it with AS5...no change. I went from 3.0ghz to 3.2ghz...no change.
It does change, however, during stress testing and gaming and the like. I run prime95 and the temperatures get right unstuck and start climbing as I'd expect them to, and these temperatures seem relatively normal to me (maybe a BIT high). What I find weird, though, is, I can be in the middle of a prime95 test, and press "stop", and it'll INSTANTLY go from wherever it was, say 50c, right back down to 38. I'm not too experienced with processors or anything, but...I don't know, losing 20c of heat instantaneously seems a little odd...This happens the other direction, too, as soon as I press the start button temperature goes from 38 to 44 instantly.
So. I guess my point is, what should I do? I have a fancy semi-expensive cooler and a reportedly chilly processor and good airflow and I want to use it, dammit! But I feel like I'm going in blind, hoping that temperatures reported are reliable, at least the stress-test temperatures. If my idle temps are stuck at 38c seemingly no matter what I do, though, can I really "trust" that the temperatures are accurate? If not, is there anything I can do to overclock safely?
