- Mar 26, 2004
- 249
- 0
- 0
I'm a bit confused on this issue, so I figured I should ask for all your opinions. I recently bought a 360, and wanted to be able to set it up in my room to play when the other 2 tv's are in use. I do have a computer in my room, for which I have a 15" lcd monitor at the moment.
I figured that I should kill 2 birds with one stone, and get an HDTV so I can play both my 360, and use it as my computer monitor as well. However, I don't think I can get anything larger than a 20" HDTV because of the cost. But, I can probably get a decent size computer monitor for much less.
So my question is, Should I get a 20" monitor with an adapter to hook up the 360, or get a 20" HDTV? Would it be worth the extra money for the HDTV since I plan on using it as my computer monitor as well? I would really appreciate any input, thanks.
