- Feb 4, 2003
- 3,370
- 0
- 71
I've got a antec smartpower 350 watt with a 20 pin connecter. My system is as follows:
amd athlon 64 3000 venice
2x512 pc3200 corsair value select
dfi lanparty nforce4 ultra
connect3d x800xl
wd 120gb ide hd
maxtor 60gb ide hd
52cdrw
audigy2zs
The motherboard has a 24pin connecter and my video card does not have an external power supply. I'm concerned that my card won't get enough power since i don't have the extra 4 pins. I plan on ocing the cpu as far as it will go without increasing vcore. Should i get a new ps, get a 20 to 24pin adapter, or just plug the 20pin into the 24pin?
connect3d x800xl
wd 120gb ide hd
maxtor 60gb ide hd
52cdrw
audigy2zs
