Should I get 19" Wheels for my car?
Dr. Detroit
8,250
702
Can you get the Hirsch wheel in 18"?
If so I would go with that.
19" rubber-band tires on the sh!tty raods of Oregon will be hell. You will have a bent wheel in no-time.
Rogodin2
Banned
Jul 2, 2003
3,219
That's a cool wheel DBYZ-kind of like the 18s on it but without that extra rim depth on the ones I have (which I don't really like as the spoke is nerfed a little in appearance.
Rogo
Rogodin2
Banned
Jul 2, 2003
3,219
I've moved back to washington and the roads here are quite good :) But I'm going to go check what sidewall width I can buy in 19" size-thanks FMR.
Rogo
28,701
Why would you spend money on new wheels if the old ones aren't broken? You can't see them when you're driving and, the car being a Saab, the only other person who will seem them is your mechanic.
mugs
48,920
46
I don't like those 3 spoke wheels at all.
And your pictures aren't very useful for deciding if 19" is too big, because I can't really distinguish the tire from the wheel well. 19" is probably too big.
spidey07
65,469
I think the ones you have on look much better than the ones your contemplating.
just MHO.
Feb 10, 2000
30,029
66
just MHO.
Copy that. The 19s look worse, will make your ride worse, and just seem like a waste of money to me.
SSP
17,727
Half a pound total? You can negate that with a bag of groceries. Or not taking a dump.
I think the 5 spokes look better.
Rogodin2
Banned
Jul 2, 2003
3,219
The problem is that the 18s don't fill the wheel wells at all. Though with the spring/shock kit it will be tighter/lower.
I'm my own mechanic :) so no worries.
Strut Bearings :Q Similar to muffler bearings ;)
Rogo
MikeMike
45,885
66
why not buy a set of the original Viggen wheels, and just be warned that they are like rubber, and will bend easily.
there are a TON better wheels that will look better than the 3 spokers you posted.
Feb 10, 2000
30,029
66
Originally posted by: Rogodin2
Don
What 19" would you get with a 110x50 bolt pattern?
Rogo
I don't pretend to be a wheel expert - I like your stock wheels fine, and better than the 19s you're looking at. Is this a rare size?
Shame
2,730
Originally posted by: SampSon
No.
When I opened this thread, I was thinking there is a post in here from SampSon that simply stated, "No."
OP: Uh... No. Don't do it.
Rogodin2
Banned
Jul 2, 2003
3,219
The pattern numbers are a rare 110mmx50mm.
I had the original nonbent stock 17" Viggen wheels (which are Moda fs1s-super soft and didn't like them) and sold them for $950 :)
I want 19" wheels and there are very few that fit the Viggen-the Hirsch are the best I've found that I like.
Rogo
Nebor
29,582
12
Rogo
BBS RGR or HREs can be custom drilled for your application.
