Should I expect problems between 2 sets of Logitech Cordless mouse/kb placed closely together?
joshg
1,359
I'm debating on buying a Logitech Cordless MX Duo set for each myself and my wife. Our computer areas are set up about 4-6 feet apart from each other... should I expect interference problems if I buy two identical sets, or is there a way to modify the frequency (if they aren't already different from each other?) so that this shouldn't be a problem?
TIA!
McCarthy
No problem. When you set it up you synch the keyboard and mouse from one set to one transmitter/receiver. Do the same for the other. Never had mine happen to hit the same between sets, but even if it did happen you just redo one. Takes a few seconds.
