Should I cover my car with a car cover at work?
jtvang125
5,399
51
There's a few small trees that provide shade just big enough to cover the cabin of the car. I get to work before most people so I usually get a spot with a shade most of the days but after coming back from lunch it's a different story.
I currently have a generic car cover and would like to start covering my car everyday but I don't want to look like an idiot since no one else covers their cars at all. Even people with nicer cars than mine don't bother with it. I would like to cover mine to protect from not only the sun but tree sap when I park under the trees.
SVT Cobra
13,264
Unless your car is perfectly clean (which it won't be since you drove it) you are going to scratch it up by removing and putting on a car cover everyday. Car covers are for long term storage. As long as your car is waxed then you are fine.
radioouman
8,632
I've rubbed off some of the clear coat on a paint job by using a car cover. I wouldn't recommend using onw.
Pacfanweb
13,155
59
That is getting WAY too anal. Plus, as others have said, you can damage the paint unless the car is clean.
I wouldn't bother.
Crafty35a
253
Yea, honestly if someone at my workdid that, they would be the laughingstock of the office (and rightfully so, that's pretty damn anal). So I would recommend not covering it for that reason alone!
