Should I change my case fan to low?
imported_mson
29
I currently have my case fan set to high and my cpu stays around 35c. I would like to turn the fan down to low but if it will affect the cpu performance or life I can deal with the extra noise. What do you guys think?
furballi
Banned
Apr 6, 2005
2,482
Run Prime95 at MAX HEAT. Use the lowest fan speed that will keep the CPU temp around 55C.
