i love my new shuttle.
i was all pumped until someone sent me a link to a review of shuttle at toms hardware, that said there were issues with the poor cooling in the shuttle... and that
http://www6.tomshardware.com/howto/20030722/mini-pcs-15.html
"Especially when using a fast CPU (2.8 GHz and higher) in combination with an efficient AGP graphics card (ATi Radeon 9700 Pro), a hard disk with 7200 U/min and a CD drive, the limits of this mini-system become evident. As the fan of the heat pipe is the only circulation provider, the airflow does not reach the hard disk. The result is heat congestion (sandwich arrangement), so that outages can be expected when permanently in use. "
and
http://www6.tomshardware.com/howto/20030722/mini-pcs-23.html
"Temperatures of more than 50° C still build up within the Shuttle housing (hard disk sandwiched with CD ROM), which may cause damage when permanently in use. There is no defined air circulation."
i currently have a Lite-On 52X CD-RW, Sony Floppy Drive, and Western Digital 120GB SE drive in there, along with a Radeon 9600 Pro and an AMD 2500+ Barton. should i be worried about the hard drive?
only two alternatives i see are:
1. i have a Maxtor 7200rpm 40GB HD that is half as thick as most normal HDs. i figure if i use this instead, the hard drive wont be as overheated
2. install more fans in the shuttle... the only place that looks like i have any room, is on top in the rear. i dont know how much difference that would make (a fan blowing in)
so, should i be worried in the first place, and if so, what should i do about it (other ideas welcome)
~Zippy!
and
~Zippy!
