Drunkentig3r
I'm going to be reformatting my hard drive soon, and so I figured its time for some "spring cleaning" for my computer. I am going to be performing various little tasks to keep my computer running cool and stable, such as typing up loose wires with zip ties, doing some vaccuming to remove dust, as well as getting a new Heatsink/Cooler (Arctic Cooling Freezer 64 Pro). Another small upgrade that I'm considering is purchasing fan filters for both my front and rear case fans. I am using two Antec 120mm case fans, and am considering purchasing two Compusa 120mm Fan Filters . Reason being is that my room tends to get pretty dusty even with regular cleaning and sweeping, and over time a lot of the dust ends up piling inside my computer case. Hopefully, if I add these filters, it'll help fix the problem.
Now, I'm hoping for big dividends for my small investment (Filters cost $2.00 each). My only concern though really, is that perhaps by adding these filters, I'll somehow end up constriction the amount of airflow that enters into and exits my case. I mean, I'm not too concerned over the brand of the filter (I would think they are all the same). Are my concerns justified, or am I just overthinking things?
