- Oct 14, 2006
- 2,012
- 3
- 81
So I have to determine whether strong nuclear force or weak nuclear force has a shorter range. We all basically agreed that it's either strong nuclear or weak nuclear, but they're all saying weak nuclear has the shortest range. What do you say?
The question:
Which of the following fundamental forces has the shortest range?
a. gravitational
b. electromagnetic
c. weak nuclear
d. strong nuclear
e. They have equal ranges.
Info from textbook:
"The strong nuclear force holds the protons and neutrons together, even though the protons are influenced by the electric force of repulsion. This nuclear force is a short-range force but is much stronger than the electromagnetic force. It is significant only when the particles are close together.
The weak nuclear force is responsible for the interactions involved. This type of force is noticed only at extremely small distances."
Weak Nuclear = less than 10^-18 m <-- Range
Strong Nuclear = less than 10^-15m <--- Range
The question:
a. gravitational
b. electromagnetic
c. weak nuclear
d. strong nuclear
Info from textbook:
