sharkeeper
Well some may want to substitute couch for bed but to each is own!
Instead of using a passive woofer box on a LFE amp, run your speaker wires to an oil burner ignition transformer. Of course the xformer is ideally suited for 60Hz so Eminem would probably shock your dick into the next dimension. (I would not recommend this!)
Imagine a movie like War of The Worlds with the first attack scene, up close and personal if you would. Those "death ray" things packed a tremendous wallop LF wise.
So instead of shaking the walls, moving the air we want a twist. Wire the transformer secondary (the terminals that produce the high voltage - 10,000 volts at 23 mA to be precise if the primary sees 120VAC at 60Hz) so that one side is strapped to a spring in the couch and the other to a floor mat containing wires. Modify as necessary to fit YOUR room!
Now when these tripod things cut loose, everyone will be in for a hell of a shock! I really want to try this (I have quite a high tolerance to pain from electrical shock) but I'm not sure how my wife would react.
For apartment dwellers this may be a decent compromise as you won't wake the neighbors and if you screw on the couch they will think you're doing the dastardly deed yet again. 😛
Cheers!
Cheers!
