Shift key not working
imported_Slip
HEY EVERYONE. I HAVE A COMPAQ EVO N1000C LAPTOP AND THE SHIFT KEY DOES NOT APPEAR WORK. IT IS EXTREMELY ANNOYING AND I HAVE NO IDEA HOW TO FIX IT. SORRY BOUT THE CAPS.
THANKS
SLIP
natto fire
7,117
10
FYI, you can disable caps lock via the caps lock key. Not sure what to do for the rest of your problem...
corkyg
Elite Member | Peripherals
27,370
240
Caps Lock does not disable the shift key - it simply reverses it. Shifts made when Caps Lock is on become lower case. This is a hardware problem that may not be user solveable on a laptop.
There are two shift keys, and if both do not work, it is not a simple mechanical failure, but probably deeper where the two signals meet to send a scan code. It could require a keyboard replacement.
