Sharing a hard drive between Mac and PC?
Chiefcrowe
What is the best way to format a drive or use other software so that I can use a 1 TB external drive interchangeably between a mac and a windows 7 pc?
exFAT will do it.
Or, if you want to spend money, you can get ParagonNTFS for OS X that will let you read/write to NTFS drives from OS X, and read/write HFS drivers from Windows.
thank you. exFAT is read only on windows if formatted by a mac though, right?
Not that I can recall, no. But it's been a while. There are other issues with it that made it too annoying to work with day in and day out for me, but if you have a blank drive, give it a whirl.
Any drive (internal or external) can be formatted by Windows in NTFS, and will be read-only by OSX "natively": without a 3rd-party software requirement. A FAT32-formatted drive has combined: read and write capability natively in both: OSX and Windows. FAT32 has a file size limit of 2 Gb.
Right.. i thought about FAT32 but I would like to use the 1 TB drive as one volume, which won't work with FAT32.
If the external drive is connected via USB, then it can be formatted by Windows in NTFS, and will be read-only by OSX "natively": without a 3rd-party software requirement. A FAT32-formatted USB drive has combined: read and write capability natively in both: OSX and Windows.
You mean 4GB file size limit. (hence the 32)
exfat should work in windows. Else, buy an NTFS driver for osx - I did the latter.
It will work, you will have a file size limit of 4GB which is okay for most people.
Koing
If you want to avoid all problems with exFAT, format the drive in Windows with a cluster size less than 1024K. Otherwise you will have issues.
Thanks everyone for your feedback. I'm going to try to go with 512K and test it out.
EDIT: It seems to work nicely.
