Hello - I guess this is the first time I've tried this and I can't get it to work.
On an XP box, I installed a local printer (HP Photosmart) connected by wifi.
It's working fine. I've have gone into the properties and have turned on printer sharing.
On a 2nd box (win2k), I have added a new network printer, pointed it to
\\pcname\printername.
the wizard asks me if I want to make it the default printer, I reply, yes, then the wizrd tells
me it has finished successfully.
However, I'm unable to print to it. If I right click it/properties it says "Driver settings
cannot be displayed. The driver for the specified printer is not installed. Only spooler
properties will be displayed. Do you want to install a driver now"
If I attempt to print from Firefox (for example), it fails with an "unknown error"
Perhaps I don't understand how it works. I though when you attempt to print as a
network attached client, it uses the driver in the host machine. The HP Photosmart
doesn't even have a win2k native driver.
Any tips appreciated.
