Shared Network Connection Via Ethernet Cable
Xyrate
84
I have a desktop, that is connected to the internet via a wireless linksys card, and i have a laptop that usually is in the same room, and instead of buying another wireless card, is it possible to share the one connection via an ethernet cable? both systems are running windows xp and have an open ethernet port, if anyone can steer me in the right direction i would appriciate it.
Thanks, Mike
hjo3
7,354
4
Yes. Just enable internet connection sharing in Win XP and use a crossover/patch cable.
Xyrate
84
well i already had the cables and cards, so i figure y spend more money but if there only $20 then i will consider it
brunswickite
6,386
bump have same problem, so all i need is a Crossover cable?
also is it possible to share connection with linux and win xp?
