Originally posted by: Tizyler
Aikouka, is there any specific reason you didn't put points into Improved Mind Blast and Shadow Power?
Improved Mind Blast isn't worth it nor will you use it often in PVP or PVE.  Priests cannot and rarely do not get those opportune attacks.  You may only ever get 1 Mind Blast off in a fight, because unlike Mages and Warlocks (depending), you can only force people off you with a Fear (every 26 seconds via talents).  Because of this, it's simply not worth it, as a good player will jump around you and run through you to disrupt your Mind Blast.  So, essentially, it's not worth lowering the cooldown.
In PVE, my fights usually go like this (with buffs already on):
Attain max distance or close to it -> Power Word: Shield -> Mind Blast -> Walk Backwards + Cast Shadow Word: Pain -> Cast Mind Flay -> (sometimes!) Cast Mind Flay -> Wand mob to death
			Originally posted by: beggerking
I'm confused... I thought we are supposed to focus on one tree for the ultimate 41 pt talent?.. .
The problem with the Priest Shadow Tree 41 point talent is, on paper it's not that good and really not worth it...  It can be nice for extra DPS in PVP, but it's really not worth giving up Inner Focus in my opinion.  Also, it only provides 5% mana to you (and your party) for the shadow damage
you deal.  So, to make up for the mana you cast, you need to deal 20x the cost of Vampiric Touch in the 15 seconds that it lasts.  Or 4x if you're in a party (note, this considering the fact that you're also giving mana back to your party).  This skill can work well in PVE with other shadow priests in the same party.  I know Death and Taxes defeated Loatheb with only 5 people by using Shadow Priests.  I haven't watched the video, but I presume they may have had 2 or so Shadow Priests using both Vampiric Touch and Vampiric Embrace, because replenishing the mana is so much easier with more than one priest.  Even easier too since DnT = Alliance, and if they have a Paladin, they also get mana back from JoW.
I have a tank warrior, do you have any recommandation for it? Thank you in advance.
I'm not as good with warriors, so I can only provide so much help.  I do have a 60, but I stopped playing him, because I enjoy tanking, but I don't enjoy playing with people enough
http://www.wowhead.com/?talent=TVMxdhbogMzZmZcxt0h
You'll probably like something like this build.  You can make changes depending on what type of weapon you're using, but that should work well.  It's unfortunate that they adjusted the shield talents, because Improved Shield Block was awesome when it had no precursors
.  You simply put one point in it and it would always block 2 attacks instead of 1.
http://www.wowhead.com/?talent=bxMGzbMZZVMgpMtRhz
What about this build? More versatile vs casters.
The build lacks Darkness, which is great for raising damage overall.  Mana Burn is really only that useful against priests and a priest with good mana/5 wll get around that via regen.  There's no point in using Mana Burn against a mage or a warlock, they'll kill you before you can drain all their mana (especially with their tools to get mana back).  Shamans will also kill you before it becomes worthwhile
Focused Mind isn't that worthwhile IMO.  Improved Mind Blast still isn't that worth it, just spam Mind Flay.
