Jeff7181
Yes, Oblivion tweaks are the source of this question... 😀
I'm not sure I understand the relationship between an actual shader, and the shader model rendering path... but I'm assuming the shader is the actual code (obviously) written for a specific shader model, and the rendering path is the way it's rendered, either as one version or another. Is my assumption correct?
I noticed that SM 3.0 shaders are enabled in the Oblivion config files, but I also noticed that the SM 2.0a rendering path is being used for nVidia cards, and SM 2.0b for ATI cards. Wouldn't using SM 3.0 shaders with a SM 2.0 rendering path defeat the purpose of using SM 3.0 shaders? Wouldn't using SM 3.0 shaders and the SM 3.0 rendering path equate to better performance or possibly better image quality?
