<< "I need NOS! I need NOS!" - Fast&Furious
"He's got enough nitrous to blow himself up.." - F&F
Nitrous isn't cheating. It's just another way to add oxygen to an engine to build horsepower, instead of using a belt-driven air pump (supercharger) or a turbine that runs off of exhaust gas velocity (turbocharger). In fact, nitrous has the horsepower advantage over both other power-adders due to the fact that nitrous oxide is stored in liquid form under high pressure, and goes through a phase change (from liquid to gas) when it's injected into the motor. This helps keep the air/fuel mixture cooler (and therefore denser).
However, running nitrous oxide on some pile of crap Civic is kind of silly. >>
Yes, no, and kinda.
First off, don't be a putz, say Supercharger and Turbocharger, I thinkwe know what they are, second your comment about it having the advantage is kinda crap.
The amount of HP gained by nitrous entirely depends on the amount you inject, and that number is final, hence, if you add a set amount of boost from a turbo or change the pulley on a supercharger, you get X amount of increase, same as you would by injecting X amount of Nitrous.
Add the weight of the tanks, the cost of refilling, and the enhanced danger in using it and you don't really find much of an advantage.
Nitrous is an easy way of doing what you COULD do with mechanics. Hence ricers love it because if it requires much more than applying a sticker it's too much work.
After all they still gotta replace the tailights.
