I have the SGI 1600SW and it's a good display made by Mitsubishi Electrical for SGI. It's the smaller version of the original Apple Cinema Display 22" before Apple switched to LG Philips. You need the SGI Multi-Link Adapter before you can use any normal video card with VGA or DVI.
we use these at work, they are o.k., nothing special.
i like my 2001fp and my 2000fp lcd's better. i am definitely NOT sayng the sgi monitor is bad, on the contrary. but like so many things in life, the price determines the "value" of the purchase. i would get one if the price was right.
