- Jul 3, 2008
- 203
- 0
- 0
My FSP-300GLS died, so I temporarily bought a cheap Coolmax CM-300 locally, but it's noisy. I am looking at getting a Seasonic ECO300 to replace it. The FSP and the Coolmax have exactly the same dimensions but the ECO300 has the protruding fan. Now, assuming the ECO300's main body is the same size as the FSP, I don't think the protruding fan will be a problem (looking inside my case), but I can't find any measurements of it anywhere.
Does anyone know if the SFX form factor with the protruding fan housing is otherwise similar to the PSUs that typically fit in a microATX case? I'm also considering the other Seasonic, the SS-350SFE, but at least one review says it is noisy. It is also more power than I need.
Note: I just found that the SS-300SFD has dimensions listed, I presume this is the "bulk" version of the ECO300?
SS-300SFD: 125mm(4.9")*100mm(3.9")*76.5mm(3.0")
SS-350SFE: 130mm(5.1")*125mm(4.9")*64mm(2.5")
So it appears that the ECO300 would be about 12.5mm taller than the SS-350SFE. Is that extra 12.5mm due to the fan enclosure? In other words, is the main body of the PSU only 64mm tall? Because my case does have a small metal stub which limits the size of the PSU to 64mm, but that stub is not large enough to block the fan.
