SFF/mobo Trouble, please help
Munkies123
I was moving my computer, a shuttle xpc around on my desktop to fit a second monitor and when i turned it back on it just stayed in my bios, nor would it go into bios settings, and instead of listing all my hardware like it usually does it only had my processor and a line across the screen. I kind of figured my mobo was fried but it booted into windows once. After that the next time i turned it on it said something to the effect of "programming lan chip" i had no idea what that meant and the bios went away screen went black and all it does it "rev" everything up all fans on high spins hdd and trys to spin the dvd rom. I rebooted cmos and nothing changed. Now thats all it does is just comes on with a black screen with everything going on high. Can you help me or do i just have a f'd up mobo 🙁
thanks for any suggestions
My guess is that it may be shorting something out. maybe you have something loose inside that knocked free when you moved it.
Could easily have f'd up the mobo at this point.
Depending on the age of the system, Shuttle might RMA it for you.
