- Sep 6, 2005
- 3,822
- 1
- 81
I never though I'd find myself posting here, but I feel like moving my system into a smaller form factor and I'm lost in this world.
My eye is set on the Silverstone SG08 or FT03 Mini, however I'm not dead set on these cases. I do want an aluminum case (either partly or fully), with a clean face (which is why I'm not partial to the SG05 or Lian-Li Q08, but I can be convinced otherwise). The PC-Q11 looks good too, but it seems to be an older model and less efficient for a power cube.
Basically, I need help picking out a nice case that is good for my build, and a motherboard to go along with it. A good small CPU cooler. A PSU that will work as well. I want to re-cut all PSU cables to length, I need to know what pins to get, and what crimp die I need.
Special Need: We have a pretty bad wireless situation going on in my apartment right now. My roommates get dropped wireless from the second floor, due to interference from the first floor, I'm the only one to get a solid connection because of my wireless PCI card (Rosewill N300). I need an ITX motherboard that has a solid wireless solution (my roommate's Asrock Z77 ITX drops internet all the time), or I will need some kind of external USB antenna or booster for the built-in adapter.
1. What YOUR PC will be used for.
Gaming.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% For this switch, let's say around $300 before selling old parts
3. What country YOU will be buying YOUR parts from.
US, with access to a Microcenter (albeit slightly out of the way)
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Silverstone, Lian-Li, or any higher-end case manufacturers
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Everything except case, CPU cooler, PSU and motherboard, perferably. i5-3570K, Patriot Viper 3 DDR3, Galaxy GTX 670, 1 SSD, 1 HDD
7. IF YOU plan on overclocking or run the system at default speeds.
I do overclock but nothing special. I try to keep overclocks reasonable
8. What resolution, not monitor size, will you be using?
9. WHEN do you plan to build it?
