- Oct 9, 1999
- 5,196
- 3,824
- 136
I realize that SSD's which use the Sandforce 2281 controller compress data to increase transfer speeds. My question is when data is written to the drive does the the drive indicate a reduction in capacity based on the compressed or uncompressed size of the data written?
For example. Assume you write 500MB of data to the drive, which the drive compresses to 300MB. Will explorer or whatever disk management tool you use report that the capacity of the drive has reduced by 500MB or 300MB?
I assume it is 500MB and the drive still has that 200MB of space free. But I'm not sure. This would make sense as to why these controllers don't perform well when they are filled with in-compressible data because when they are filled they are really filled! But if they are "filled" with compressible data then they really aren't filled and there is still room for the drive to operate efficiently.
And now my second question is why do other controllers, ones which do not compress data handle the full scenario after a TRIM pass so much better than the Sandforce controller?
Not sure about all this and now that SSD's are here I'd like to get my facts straight.
