No so much a mod because I'm building it from scratch. Noise means nothing, this will be in my basement, CFM is everything! I've been dreaming of something like this for a while now and finally figured out how to implement it. I'll get pics up when I can.
OK, I start with a 2' by 2' 7" box (internally about 8" height) made of wood, originally used to hold some kind of power-plant parts (like turbine blades or something.) I'm attaching a window-mounting exhaust fan on top that is about 2' by 2'. The bottom part is raised, here's an attempt at a drawing....
......___________
../OOOOfanOOOO\
/-----------------------------\ <--lid will be hinged on.
|xxxxxxxxxxxxxxxxx|
|xxxxxxxxxxxxxxxxx|
__________________
__II____________II__
ok that kind of sucks but basically metal posts (the II's) connect 2 boards, this is the base. the '.'s are just for spacing
so I'm gonna cut a hole in the board that forms the bottom of the box so the air will effectively flow in through the fan, out the hole and sideways out the space in the bottom. Finally I'm going to disperse the parts of the system throughout in a patern I've already worked out, might as well make a picture for it:
___________________
|empty_________power|
|empt|..holehole..|suply|
|empt\..holehole..|suply|
|empty\.holehole./HDD.|
|^^^^^^^^\|...hole..|..rack.|
|mother/|...hole..|empty|
|board\..|______|...CD..|
|_____/_flopy___ROM_|
Out of the front: CDROMs will be mounted vertically (open up) and slide out in a cabinet thing. The floppy will tip out on a hinge (hinged at the bottom, open up.) HDDs will be in a 3.5" holder taken out of a case and seated in a base. The power supply will have it's cover taken off and replaced by a metal grate (so it has airflow and is still protected.) I'll drill custom holes for the mobo screws. Empty space is for water pump or something.
Pretty crazy stuff, I'll probably eventually have a 72W peltier + water cooling setup. I'm thinking about lining the bottom-outlet with fans to increase the output (and so the air knows where to go!) I hope my explanations haven't been too befuddling, now to the actual substance of this note...
QUesTIon-s
1. Can I get a power supply with longer cables--specifically the 4-pin cables--or will I need extensions for them? Do most higher-end ones have longer cables?
2. Can I mount hard drives vertically(short end straight up)? The HDD I have now is an older 8.4Gig but I'm getting IBM deskstars.
3. On the same note can I mount CD(&DVD) drives vertically, as in with the tray opening upwards? Would I have to use those little clips on the tray all the time? What if I had slot loaders?
4. Can anybody think why any of this would be a bad idea?
5. Processor suggestions? I'm going AMD don't question that, I'll probably wait and see what people do with .9-1.2 GHz Thunderbirds as far as overclocking goes. And see when >12.5x multipliers come out. I guess I could mod that too....
That's all for now, thanks alot, this isn't the last you'll be seing of me I'm sure. (General comments are welcome btw)
......___________
../OOOOfanOOOO\
|xxxxxxxxxxxxxxxxx|
|xxxxxxxxxxxxxxxxx|
__________________
___________________
QUesTIon-s
