Settings to export/print from Lightroom?
thestrangebrew1
So I took a few pictures for a friend of mine to give to her dad for xmas and when I sent her the pics to print, they came out looking a) vastly different from our phones (iphone and samsung s8+) and my monitor. Colors look way off on the print, slightly different between phones and my monitor. She uploaded them to Costco and had them print it out and it came out slightly pixelated and portions of the photo appeared to be blurry. I don't normally print, typically I just text images to friends and they'll post on social media, so this is a first to me. Can someone tell me if there is a process or workflow to properly either export/print the file after working in Lightroom?
Is you monitor calibrated?
5,720 x 4,195‬
I think she tried printing at 11x14". I'm assuming this is a standard size for a print to get framed.
That res is fine for that size print. Are you sure when you sent the pictures that the method you used to send them did not compress or downsize them?, facebook for example will always compress your pictures, as will alot of social media apps/sites.
Unless the picture was out of focus it should not be blurry or pixelated at that res and print size.
I just copied the image to her flashdrive. It was a 29MB file that copied over. I wonder if uploading it to costco somehow compressed the image. Maybe there's some kind of resolution limit that changed the look of the image.
Its likely to be aspect ratio then, did you crop it to size for a 11x14 print? because 11x14 aspect ratio is not the same as the 5,720 x 4,195‬ picture sizes aspect ratio, so if its being stretched that would explain the distortion.
I didn't do anything after I gave her the file. Neither 1 of us knew anything about having to crop to size for the print lol. Something I guess I'll have to research and learn how to do for specific print jobs.
Sent from my SM-G955U using Tapatalk
What camera did you take the photos with? And how big, and what resolution, does your monitor have? If you worked on/viewed an image significantly smaller than the print size, you may just not have seen defects in the original photo that became obvious when it was enlarged. Lesson Number One of digital photography is that higher (digital) resolution doesn't automatically give you good/pictures just because "moar pixels", and viewing a high-res image at a small(er) size will mask defects that become obvious when viewed/printed at a resolution that more or less "just fills out" the image space.
As for future workflow for print work, I think your first step needs to be "calibrating" your familiarity/expectations/technique to the sort of image quality your camera can produce at the resolution/image size of the photos you want to end up with. If, for example, you're using a phone camera, you're going to have be a lot more careful about taking the original photos if you want good looking 11x14 prints than you have to be to get good looking social-media-size "snapshots". Assuming the camera is capable to taking photos of the quality you want in the first place, of course...
As for the monitor's calibration, that wouldn't (or shouldn't) have anything to do with blurriness or pixelation, rather than the image color and characteristics like contrast and "brightness" that ultimately depend on color reproduction when printing photos. But when printing photos, you also need to know what color space the printer/lab uses and how that relates to your monitor's specs and accuracy. And for "really good" prints, you're probably better off using a pro/prosumer lab, too.
Good points. To answer the above questions, I use a Canon 80d to shoot, and have a 27" Dell U2718q 4k monitor. As I mentioned above, I don't print my pics personally, I just take them and give my friends the file and let them print it where ever, but I wanted to know if there was some kind of setting I should use prior to giving them the file that they could take anywhere and print and look good. Your tips give me a good reference point to start looking into.
29MB? Was that a RAW file or in TIFF format? Most of the jpgs from my 24MP Sony is in the 8MB range. If I export from LR at max jpg quality they're only around 12-15MB
I rarely print but my wife and sister have printed hundreds of my files at Costco with no issues.
It was a jpeg I believe but I kept the resolution at 5,720 x 4,195 when I exported. I'll have to check the exact settings but I'm pretty sure I set the pixels per inch at 300 also.
Thanks! This makes so much sense now!
Changing the aspect ratio wouldn't alter blurring or pixelation, it would just change what's visible in the photo - as in more or less of it would show up on the print or dead space would be added around the border of the image as black/white "bars" (the same way video shows up on a monitor when AR is mismatched). The printer would have to actually use "differently shaped" pixels to alter the fundamental geometry of the image itself, and I've never even heard of a photo printer doing that (nor can I imagine why they would?)
When I want to print, I usually do a few things in LR:
1) crop to the desired aspect ratio
2) export to Tiff
3) tell the print company to not adjust the colors (at least this is an option with Adorama)
Haven't had a problem yet with following these steps.
