PrinceXizor
I have to use an older comp at work (for 3D no less) and I need to maximize its speed.
The mb can run either at 100Mhz or 133Mhz and the system currently has 1GB of PC2100.
It supposedly can run the memory at 100Mhz w/ tigher timings than the 133Mhz.
The FSB of this chip is 400Mhz right?
Anyway. That should be the information you need.
Questions? I will answer as soon as I can.
Thanks for your help.
P-X
P-X
