Settings for MSI K7Pro2(newbie question)
jawaki
My MB is setup with a fsb of 100 and multiplier of 11.
Should I decrease the multiplier and go up on the fsb (to 133) as I have 133 SDRAM?:eek:
chexi
1,030
No. You can set the RAM mhz separately in the BIOS. Just take RAM timing off auto, and you will have the option to go at 100 or 133 mhz.
Davegod75
5,320
yep..that is correct...you can set the speed of your ram seperate from the FSB. THe best of both worlds
