Setting up VOIP with a gateway...
50
2,717
Hello, I am trying to setup my sunrocket service w/comcast cable internet. The instructions only show for people with a modem and a router not a gateway (modem and router built in one). Should I plug one LAN port from my gateway to the LAN port on my sunrocket box or to the WAN port on my sunrocket box? I tried both and it won't respond. How do I set this up? Thanks
georgepa
498
Hi-
I have a modem/router combo which came with my Verizon FIOS. I just plug the gizmo into one of the available LAN ports on the back of the modem/router, using the WAN port, and it works fine. Be sure to shut your modem/router down, then plug-in the gizmo. Then turn on the modem/router, then turn on the gizmo. You should get the voice light and dialtone.
