Setting Up Linksys Wireless with XP
BlakkIce
1,073
Hey guys im having trouble setting up my wireless router and card under winXP it worked fine in win2000. I thought XP had built in drivers to connect to the router? Im getting a Link connection on the wireless card and some flikering on the TX but i cant connect to the internet in IE. there is no WEP settings or Essid
Muadib
18,099
901
Linksys still hasn't done their xp drivers. I don't have the router, I have the WAP11. It works, but you can't have encryption turn on.
According to their site, the drivers should be out soon.
SteelCityFan
782
I have the Linksys Wireless Router and their PCMCIA Laptop Nic card (Version 2.5), and all works fine. If I recall correctly, there was a firmware update for the card to enable some Windows XP Wireless connection monitoring thing.
It does not require any software other than the drivers I got from Linksys webpage (Don't think Linksys Network monitoring stuff works). I see a network strength meter in the connection properties, and can also see it by mouse-overing the connection icon in the system tray (standard icon ... the 2 PC's).
SteelCityFan
782
OK, I just pulled my laptop up.. In the network connections, I have all listed. One for the Internal Cat5 connection and one for the Wireless network connection. To get the the WEP key, double click on the Wireless connection then hit properties. Move to the "Wireless Networks" tab. It will display all wireless networks available here. You can connect or change settings with the Configure and Properties buttons. The WEP key is in the Properties.
I think this only works if you update your firmware on the card, which was triggered by XP or Linksys' updated drivers.
BlakkIce
1,073
i cant get a firm update its greyed out and i dont know which verson of the card i have i have had it for a year
SteelCityFan
782
Like I said..
If I recall correctly, once I installed the drivers (on Linksys' page), it prompted me to update the firmware automatically.
To find the version of the card, just look on the front/top. Right under "Network PC Card" it will have V2.5 or V3.0. If nothing is there, I would assume you have version 1.
