Hi all,
I have had this set up over a year so I know it can work but after a recent issue with my network not getting past the router to the internet, I am wanting some confirmation that what I have set up is correct and as safe as it can be.
Equipment I am using:
5 Dlink DCS930L(wireless)
2 Dlink 920(wireless)
1 Trendnet PTZ(wired)
2 Foscam FI8905w(wireless)
Netgear WNDR3700 router
Linksys WRT54gs(w DDWRT) acting as a wireless bridge
Linksys WRT54g(w tomato) acting as a wireless ap
I have all of the above running and are accessible via my android phone. I monitor with Blue Iris software.
From what I understand, I need to have a separate internal IP addresses with ports setup up on each camera. DHCP disabled. I typically stay in the 192.168.1.40-60 range with ports in the 40-60 range(as long as the router lets me).
I have my desktops(3) and laptops/tablets(2) running via DHCP so the IP's get assigned.
Over the weekend, I could not get to the internet on any of my devices. If I bypassed the router, I could get out. Netgear tech said the router was fine as well and blamed an IP conflict on my PC? I ended up having to factory reset the router and started re-doing all of my port forwards. Bad thing was that the router would not allow me to use some of the original port addresses. I think last time I might have turned off DHCP on the router and assigned the IP's and then turned it back on - was this wise?
Questions:
I have read some but as you can guess, I don't always understand what is happening...
*My computers are getting intermittent outages still and I am not sure if it is my router or my setup or both? ISP claims the router or my setup is the cause.
*Can I have too many ports forwarded? I had 14 on the last setup including cameras, xbox, play on server and a Reefkeeper net module.
I use the linksys 54gs as a wireless bridge on the fish tank monitoring software. The wireless router prevents any ground loop issues. I am using the 54g as a repeater. It is setup with the same SSID and password and does appear to work but I have read conflicting info on this setup.
**edit** Tonight my wife was complaining about the internet dropping and I set up a fixed IP on the network connection on her desktop. This seemed to be working as I had done this on my desktop as it was recommended on Port forward.com. It seemed to fix the issue.
When my tablet/smart phone seem to be going no where, the 2 desktops seem to get through now. Not sure what is happening.
Any thoughts or ideas?
Thanks
Questions:
Thanks
