Hi All, a friend of mine has asked me to setup a wireless network in a building he owns. The building is a 7 floor building which includes the ground floor. At first he has asked me to setup a wireless connection because he didnt want wires sticking out everywhere so I have purchased 4 access points to turn them into repeaters that would extend the connection to every floor (please see setup 1 photo for a better idea). After I have set this up I took my laptop and phone to every single corner of the building and the connection was very strong and working great. I even went up to the roof and the signal was strong. I walked outside of the building for about 20 feet till finally it was disconnected, so he was very happy with the job Ive done until about a day later when people in the building were complaining they were not getting connected. I dropped by to see what was going on and they were right, there was no connection except for the 3rd floor where the modem/router was
. I had to take out all the access points from their metal protection box insert them back to the laptop and set them up once again to get a connection. The connection worked for another day or two then again same problem
. The hardware I used is on the bottom and I will attach photos to give you a better idea on how my setup looked liked. The modem alone could provide a signal to the whole 3rd floor as well as some areas in the 2nd and 4th floor but not all. The d-link repeater was setup on auto channel and Im unable to edit any ip settings unless I turn it into an access point. So it was setup as DHCP. I decided to use setup 2 (photo below) where I connected the modem to a switch and there was a wired access point on the 2nd floor and 4th floor but for some reason I dont seem to get any connection on those floors. The access points were setup on auto channel then I changed 2nd floor to ch6 and 4th floor to ch11, yet still did not work. The modem/router ip is setup as 192.168.1.1 and the access point on 2nd floor is 192.168.1.2 and 4th floor its 192.168.1.3. Access points are setup as Static IP but modem/router is setup as DHCP. Im not exactly why Im not getting a signal someone please help out, I really tried everything and dont know what Im doing wrong.
please see pictures below
http://imgur.com/a/kSazV
HARDWARE
HARDWARE
- D-LINK DAP 1360 ACCESS POINT
- MODEM SAGEMECOM 2704 N
- SWTICH D-LINK DES-1008A
