Setting up a RAID1 and using another SATA drive alone
btsdev
186
Hey guys,
I have a MSI K8T Neo FIS2R motherboard. It has 2 sata controllers: a VIA southbridge controller and a Promise controller. Both have 2 sata150 connections (so 4 total).
I currently have a 74gig (sata150) Raptor, and I am purchasing 2 sata300 500g drives to put in a RAID1. So I have 2 questions:
1. I'm assuming the 500gb sata300 drives will come with jumpers to reduce them to 150 speed... is this a safe assumption?
2. Can I put the 500gb RAID1 setup on one controller and the lone Raptor on the other controller?
2a -- If yes, which would be better to run the RAID1 on, VIA or Promise?
Thanks,
Brian
cprince
963
Yes, you can do RAID on one controller and have the Raptor on the other controller. I would use the Promise controller.
