I've got 2 machines connected to the net via Linksys BEFSR41 router. One upstairs, one downstairs. There is a printer connected to the one upstairs and i'd like to be able to use it from the machine downstairs. How do i do this?
1) Install the print server drivers on each computer which you wish to use the printer on.
2) Install the printer drivers on each computer which you wish to use it on.
3) You need to make sure the port for the printer on all of the computers is configured as. "PTRMate (Or whatever your print server software names it)" and also you want to make sure you have the IP to the router correct.
It may seem complicated, but I've done it so many times on my computers that I can do it in my sleep 🙁
