setting up a mixed G and B dual AP network
imported_Woody
294
Another good use of dual routers is for managing mixed wireless networks. I just picked up a new linksys WRT54G to replace my older linksys wireless-B router. Since I have four wireless devices in my house and one of them is B while the rest are G I didn't want the B device to slow down my whole wireless network whenever it was used since a single B device will revert the entire wireless network to it's slower speed when it's connected.
The solution was to set up the older linksys b router as a "router" rather than a "gateway" with a dedicated static IP on the LAN (I don't use DHCP at all). This way I have two wireless access points each dedicated to the separate protocol. You set up the channel for the B router to the opposite end of the G router. Since there is some overlap of frequency on wireless channels I simply set one of them at channel 1 and the other at channel 11 to minimize any interference. I live in a fairly rural location so my neighbors shouldn't complain that I'm hogging all the frequencies! ;-) this may be considered somewhat rude in an apartment or condo complex.
The G router is connected to the cable modem and has the firewall features enabled. You could do it either way but since the G router is newer with better firewall features it makes more sense to do it this way. It also keeps the traffic across my old crossover cable to a minimum.
I then connected the two routers using a crossover cable plugged into one of the four ports on the B router (not the WAN port). I tried using a standard cable into the WAN port and it didn't work. I set the G router to broadcast wireless G network signals only so my old B laptop that the kids use won't accidentally connect to it rather than the B router like it's supposed to. I set up an active MAC table on the B router to ensure only the wireless B laptop will connect to that router.
It works great and keeps my G network running at top speed even when B devices are present and connected to the LAN. I have mixed Macintosh and Windows systems and cross platform networking is working fine across the whole LAN.
Hope this helps some people.
