Thanks for the ideas! I'll go home tonight and try to figure out what I need to do. I have no idea what a DHCP is. The install disks that came with both pieces of hardware seemed to work great. So I thought that was all I needed to do.
I just got this back from Linksys Tech support...
Thank you for contacting Linksys Customer Support.
With regard to your inquiry, please be guided that the wireless
devices should be within line of sight with each other. Connecting to
wireless devices located at different rooms or floors can result in
severe
signal degradation and attenuation or even loss of signal. Also,
refrain
from placing your wireless devices close to any electronic device that
radiates signals. Electronic appliances like microwave ovens,
flourescent
lamps and cordless phones, especially those operating at the 2.4 GHz
range
can also cause severe interferrence to the wireless network signals. It
is
best to situate the wireless access point and router at the center with
respect to the wirless computers.
Note: If you have previously enabled an Internet Sharing Proxy Service
on
any of your PCs, you must disable it now.
* If you are running Netscape Navigator: Click Edit >> Preference
>>Advanced
>> Proxies> and click Direct Connection to the Internet.
* If you are running Internet Explorer v5 or better, click
Start>>Settings>>
Control Panel>> Internet Options>> Connections>>LAN Settings. Remove
the
check on the proxy setting. Click OK to continue.
Also kindly check on some Parameters that must be set properly: these
are
the channel, ESSID and WEP keys. These settings should be consistent
and the
same for all wireless devices (PC cards, access points, etc.) situated
in
your wireless LAN. Double check the WEP keys for both the wireless
router
and the wireless PC cards. Most problems are brought about by having
different encryption keys set into different wireless devices. In order
for
the wireless encyption and decyption to take place, all keys must be
identical. Usually, for the initial set up, the WEP keys are disabled
just
to make sure that there is a wireless link.
And as much as possible disable WEP.
