- May 11, 2004
- 123
- 0
- 0
well the motherboard only has a 3 holes, one for regulat speakers, lne in, and microphone
but in the manual it says if i update the driver i can have 5.1 support adn the holes and what they do will change
i did update the drivers, and i cant get it to work, anyone have any ideas?
edit: for soem odd reaosn after runnign the wizard for a 3rd time, it worked, dont no why but it did
but now the center channel wont work, in the nvidia wizard the sound for the other speakrs was white noise to test it, but when i heard it in the enter speaker it was this high pitch noise
sorry if wrong forum, didnt no if technical support or motherboard
