Setting Object Data *double* For Class ComboBox :: MFC
kuphryn
400
Hi.
I have a CComboBox object. I need to set one or more of its strings to represent a *double* data type. For example:
Code:
CComboBox mCbbCandy;
mCbbCandy.Create(WS_CHILD | WS_VISIBLE | WS_BORDER | LBS_NOTIFY | WS_VSCROLL | CBS_DROPDOWNLIST | CBS_SORT, CRect(CPoint(270, 10), CSize(100, 100)), this, IDC_CBB_FLAVORS);
// Setting its value
int i = mCbbCandy.AddString("X");
mCbbCandy.SetItemData(i, 1.99); // $1.99
// Retrieving its value
int i = mCbbCandy.GetCurSel();
double price = mCbbCandy.GetItemData(i);
For some reason, the price does not come out right if I use the decimal point. For example, any whole number works, but not decimal.
How do you set the item data to a double type? Visual C++ gave warnings about data loss because the CComboBox object expected a DWORD instead of a double.
Thanks,
Kuphryn
javathehut
318
just insert the number as a string:
TCHAR szNumber[10] = {0};
wsprintf(szNumber, "%f", 1.99);
mCbbCandy.AddString(szNumber);
The function you were using SetItemData, is used to set a pointer for reference (kind of like the lparam in tree/list views) so its not at all meant to set the value of the combo box item. Hope that helps
Adrian Tung
1,370
javathehut's suggestion will work *unless* you want what the combo box to display to be different from the data that you retrieve from it. If so, you can do a little hack to get your data stored and retrieved properly:
Do a memcpy to copy your float to a DWORD variable, then use SetItemData to store your DWORD. When you need to retrieve the float, do the opposite - use GetItemData to get the DWORD, then memcpy it back to the float. Both DWORD and float are 4 bytes, so memcpy will work.
Hope that helps,
:)atwl
Edit:
Ignore my first suggestion, I just realized you want a double, not a float. A double is 8 bytes, so there's nothing that you can do except for javathehut's suggestion. Unless you use a pointer to a structure/array/list that stores your double, that is.
