Setting CPU Speed
punkemon1
12
I replaced my Epox 8K7A+ MB several months ago with the same model and just discovered that my WIN2000 system and other pgms are displaying my CPU speed at 1 GHz instead of what I actually have, an AMD Thunderbird 1.4 GHz. I checked out the BIOS and reviewed the manual, maybe I missing something, but couldn't find how to adjust to have the CPU identified as 1.4GHz. Not sure if it's a jumper or BIOS setting, can anyone help? Thanks!
bgeh
2,946
if i am coorect the 1.4 thunderbird's jumpers are set as 10.5 x 133 fsb
so your bios should be showing it as 1050 mhz
the way to solve this problem is to set the fsb as 133mhz
you can do that by either changing the setting in the bios
or
changing the jumper
punkemon1
12
Couldn't find the setting in the BIOS but was able to track down the correct jumper and changed it. CPU speed now shows as 1396Mhz.
THANK YOU!!
