Setting AHCI / IDE to IDE mode, limits xfer speeds to 150MB/sec?
VirtualLarry
56,571
10,206
Is this true, that you get a max of SATA 1 (150MB/sec) in Win7 if you set your mobo to IDE mode?
Because that seems to be what I observed with a friend's computer lately.
Cerb
17,484
33
86
Maybe? I've only ever needed that with HDDs that couldn't even do 100MBps. Since that setting is to handle legacy devices and OSes, it wouldn't be surprising, but I'm not sure that it's necessarily the case, either.
VirtualLarry
56,571
10,206
The rig is a 780G mobo, with an Athlon II X4 3.0Ghz. Drives include a new 500GB WD Caviar Black (which I am told is AF), and a 30GB OCZ Agility SSD as the OS / boot drive.
Running HDtune, I get a virtually straight line for the WD Black at 130MB/sec, and the same with the SSD, except pinned to 150MB/sec. I know for a fact that that SSD model is capable of 180MB/sec or more, so it's clear that there is some sort of interface limitation going on.
Engineer
701
SATA I has a max speed of 1.5Gb(its)/sec...so 150MB(ytes)/sec would probably be pretty close to the MAX limit anyway whether it be IDE or AHCI.
VirtualLarry
56,571
10,206
But why would a SATA 2 SSD, and a SATA 6G HDD, be running at SATA 1 speeds, on a SATA 2 mobo?
Elixer
10,371
762
Because 'IDE mode' limits it to the max that mode can handle ?
Moral of the story is, don't use IDE mode if you want full SATA 2 speeds.
Engineer
701
Oh sorry, I misread your first statement as the device or motherboard was limited to SATA I because that's what it was designed to do. Didn't realize that they were SATA II or III devices.
BFG10K
22,709
3,002
Absolutely not. Here's my old Intel 320 SSD running under IDE mode on said OS:
