BFG10K
Good luck if you're buying a B560 chipset as some can't even fully raise the limit due to VRM throttling.
The reviewer makes a good point about the ludicrous ever-expanding gap between base clock and boost clock, and how technically only running at base (65W in this case) is still "Intel spec".
