Hello Guys, I want to setup a HotSpot around a gated community that has atleast 100 Buildings, not higher than two floors each, and trees are also on path. I've been looking in different antennas and range extender amplifier and to many to choose from. My main goal is to try to cover as much area as possible without having buy big antennas and etc. This are some example that I have came up with and consideration but if there is any better suggestion please let me know. Remember is a HotSpot, all around 360 degrees. If it matters I have 2 routers, Linksys WRT54G v8 with DD-WRT running at Tx Power 160mw with heatsink and fans and the second one is a Linksys WRT54G-TM with DD-WRT running at Tx Power 251mw with heatsink, fan, W/SD/MMC Support. I live in a second floor apartment.
RadioLabs 500 mWatt 2.4 GHz Wireless Range Extender Amplifier
The antenna that this amplifier is attached with is a 5dbi but want to upgrade them to a 16dbi Antenna.
2.4 GHz 16dBi TNC Wireless WiFi Omni Terminal Antenna
Upgrading the stock antenna of the amplifier for a more sensitive one.
Any suggestion other than this are always welcome. Thank you in advance.
Edit: The Thread is locked here while the discussion continues here,
http://forums.anandtech.com/me...=2332363&enterthread=y
JackMDS Moderator
JackMDS Moderator
