Case:
2x DVR system
5 Static IP - using only one because of router limitation
Access to DVR was done by typing IP address to Browser. 2nd DVR was accessible by typing IP address and :80 at the end.
One day the 2nd DVR stopped responding and I was called.
Proposed Solution:
I googled :80 and didn't find too many helpful info. Also because we have a server I think using our 5 s-IP addresses and assigning them to each DVR would be a good idea.
I've bought a switch and connected a DSL modem to the switch and pulled another line from the switch to WAN on the router. and connected other workstations to the switch.
The router (WRT54GS) has problem with default gateway. If I put in default gateway provided by ISP, internet doesn't work. I have to put in one of the IP as the default gateway and it is accessible.
I'm trying to find a right manual to setup a static IP network and how to assigning them to each workstation. because we have about 15 workstations, only DVR(2) and a server will get a static IP and rest would be DHCP assigned by the router.
2x DVR system
Proposed Solution:
