SETIQueue Question: Consolidating Clients
SoulAssassin
So I'm running my own SETIQ and I recently assimilated someone's machine on dial-up AOL. Everytime they connect to AOHell they get a new name/IP via DHCP which clutters up my clients for the next two weeks. I know I can adjust the time it waits to remove a client, but is there a way to consolidate any client with a name *.aol.com into one client? Maybe I'm just being anal but I find it annoying. 🙂
See here to see what I'm talking about.
I believe you can dedicate a port to that person and that should keep it from cluttering up the stats.
Login. Go to tools. Then use the merge two clients into one option. Duh.😛 You will have to keep doing this maually though until you cover the entire IP range your friend is assigned from but after ahwile they become further and farther between and you get a grip on the situation. Only takes a couple weeks to corale it into a minor anyonace instead of a major anoyance.
